Moran Posted December 24, 2017 Report Share Posted December 24, 2017 Hi is there a way that i can disable the touchscreen and prevent the user from pushing any buttons? Quote Link to comment Share on other sites More sharing options...
MVP 2023 Flex727 Posted December 25, 2017 MVP 2023 Report Share Posted December 25, 2017 There are multiple ways to do this, but there's not a simple System Bit to disable the touchscreen. Either create a blank HMI screen with no buttons that displays during the time you want to disallow button presses, or use the disable bit on all buttons that are on screen and activate that bit during the disallow time. I will often have functions that are only available with proper login and will hide or disable elements when the user isn't logged in. 1 Quote Link to comment Share on other sites More sharing options...
