GonzaloRoldan_ Posted January 8, 2018 Report Share Posted January 8, 2018 Hi everyone! I'm having a problem with "Insert String to String" function.. I can't make it works.. Can someone tell me how to use it, and how to fill all the operands? I just have 2 strings in differents MI, and want them to be just ONE string. Thanks in advance! Quote Link to comment Share on other sites More sharing options...
MVP 2023 Flex727 Posted January 8, 2018 MVP 2023 Report Share Posted January 8, 2018 A = Starting address of the original string B = Starting address of the string fragment that will be inserted into the original string (A) C = Offset from the beginning of the original string (where the new string will be inserted). This is in bytes - remember that there are two bytes per MI operand. D = Starting address of the final composite string Look carefully at the graphic on the FB when placed in the ladder for clues as to what each operand does. @Cara Bereck Levy, I really couldn't find any proper help on this function in the help file. Did I miss it? Also, the tool tips on this function do not provide any useful information. 1 Quote Link to comment Share on other sites More sharing options...
Cara Bereck Levy Posted January 9, 2018 Report Share Posted January 9, 2018 Adding it now, thanks Flex! Quote Link to comment Share on other sites More sharing options...
MVP 2023 Flex727 Posted January 9, 2018 MVP 2023 Report Share Posted January 9, 2018 No, thank you, Cara! Quote Link to comment Share on other sites More sharing options...
GonzaloRoldan_ Posted January 11, 2018 Author Report Share Posted January 11, 2018 Thanks Flex! It works now.. At first I looked at the graphic but I didn't get it at all.. So thanks again for helping me! Cheers Quote Link to comment Share on other sites More sharing options...
MVP 2023 Flex727 Posted January 11, 2018 MVP 2023 Report Share Posted January 11, 2018 Glad it helped! Quote Link to comment Share on other sites More sharing options...
