Fantasia83 Posted March 16, 2011 Report Share Posted March 16, 2011 Hye all, I've got a very strange bug today. I'm using a serial connection (RS232) which come from a PC to my V570 port 1. I use Visilogic 8.9.5. I have a message which is 89 bytes long using this format : [sTX] ,NumVar1[1], NumVar2[5], etc ... , stream_1[7], stream_2[7],[ETX] [EOT] The two last streams variables are stored to MI 2000 -> MI 2006, and MI2010 -> MI2016 using the option convert 1 byte received to 1 linked element. If i uncheck the parameter Fixed Stream length in the protocol scan Setting for the streams variables and if the message doesn't contain streams the PLc receive, translate all the numerical variables but it 'fill a large amount of MI with strange values From MI 0 to MI 200 and a part within MI 1900. If i check the parameter Fixed Stream length no problem, the Protocol Scan FB ignore the message because it don't have the good size My question is : Why my Operand zone is filled with strange values ? If someone had experienced a similar problem i'll be pleased to understand. Quote Link to comment Share on other sites More sharing options...
Jas Posted March 25, 2011 Report Share Posted March 25, 2011 Can you try to see if the problem still persists in the latest official release of VisiLogic? At the time of this post, that version is 9.0.1 www.unitronics.com --> support --> downloads Quote Link to comment Share on other sites More sharing options...
Fantasia83 Posted March 27, 2011 Author Report Share Posted March 27, 2011 I update to V9.0.1 ans latest V570 OS and the problem disappear. Thanks Jas Quote Link to comment Share on other sites More sharing options...
