Using beckhoff BK5120 | CANopen Bus Coupler and KL3061 analog input on Unitronics PLC V1210
Hi everybody.
I need some help because I have an issue, trying to use a Beckhoff BK5120 | CANopen Bus Coupler with a V1210 PLC
https://www.beckhoff.com/BK5110/
with the next configuration
4 KL1114 DIGITAL INPUT (4 SINKING)
2 KL1408 DIGITAL INPUT (8 SINKING)
1 KL2134 DIGITAL OUTPUT (4 SOURCING)
2 KL2408 DIGITAL OUTPUT (8 SOURCING)
1 KL3061 ANALOG (0-10V) INPUT
https://download.beckhoff.com/download/Document/Catalog/Main_Catalog/english/separate-pages/Bus_Terminal/KL3061.pdf
The issue that I have is that I've never used a Beckhoff  KL3061 ANALOG (0-10V) INPUT    and I don't know how to set up the Unitronics V1210 PLC CANopen configuration in the VisiLogic Software.
Also, I'd like to know which function can I use to read the analog input.
Does anybody did that before? I'll appreciate your help.
Thank you.
  • MVP 2023
You must build minimal Canopen configuration based on BK5110 (used  only  one of IO module).
Please read
https://download.beckhoff.com/download/document/io/bus-terminals/bk51x0en.pdf
page 114 about canopen configuration for this type of coupler.
Then use  Visilogic help with CANopen sample code to build CANopen net step by step .
Only after succesfull run CAN you  must add another exp. modules and try to read
https://download.beckhoff.com/download/document/io/bus-terminals/kl306xen.pdf
page 29 about memory mapping for analog input .
In that way i tryed  to build my first CANopen with Lenze servo.  Now it looks like simple for me, but at start i had the same problem.
Best regard
Roman
