Stefan Posted January 12, 2018 Report Share Posted January 12, 2018 Hello together, i try to measure the Speed of Rotation (between 1000 1/min and 8000 1/min) with a Samba SM43-J-TA22 and an capacitiv sensor with one srew on the Motor shaft. When i use the High Speed Input in the Hardware Configuration (Frequency Measurment 1000msec) i have an very bad Resolution (Value 16 * 60 = 960 and next Value 17 *60 =1020). I've tried to use the "Freq<- HSC" building block, but it doens't work with my values. For example im not sure what i have to chose for the Channel A, because I can chose HSC 0, HSC1 and HSC2 there but I only have two HS channels on my Samba Controller. Is this the right way to measure the Speed of Roation more exactly? If yes can you give me an example how i have to config the block, and if i have to set up the High Speed Input in the Hardware Config? Thank you very much. Kind regards Stefan Quote Link to comment Share on other sites More sharing options...
MVP 2023 kratmel Posted January 12, 2018 MVP 2023 Report Share Posted January 12, 2018 You can increase the accuracy by increasing the number of bolts on the motor shaft. Use 6 bolts and you will have accuracy of approximately 10 turns per minute.However, make sure that the sensor has the appropriate frequency range.Or use an optical sensor and a perforated wheel. Using a 2.5ms interrupt to determine the sensor signal period will not increase the accuracy of the readings.It is also possible to use your sensor, diode, RC link, and send a signal to the analog input of the PLC. This is not very accurate, but this solution has advantages.A similar scheme is used in tachometers of old cars. Quote Link to comment Share on other sites More sharing options...
sasi Posted April 15, 2023 Report Share Posted April 15, 2023 Hi, on the same topic, I'm also in a similar problem, I'm trying to measure the rotational speed of a DC fan through the tachometer that returns from the fan during rotation, what is the relevant block that I must implement in the software? Quote Link to comment Share on other sites More sharing options...
MVP 2023 Joe Tauser Posted April 16, 2023 MVP 2023 Report Share Posted April 16, 2023 To answer your question, the block is the "Frequency measurement based on HSC" block. It is located in the Utils->Immediate menu, and there's a good Help page on how to set it up. There is also an example program under Help->Examples called "V570_Frequency precise meter". But first you have to verify that you can see the tachometer signal from the fan. If this is one of those little computer fans with a tach wire you'll need to get the output type and voltage level of it to interface with the HSC input on the PLC, which is expecting a +24V signal for the tach pulses. Joe T. Quote Link to comment Share on other sites More sharing options...
