t0r3r0s Posted January 20, 2018 Report Share Posted January 20, 2018 Greeatings . Can someone post or explane me how alarms screen make on hmi ? If someone have some example that be better . Thank you Quote Link to comment Share on other sites More sharing options...
MVP 2023 Joe Tauser Posted January 20, 2018 MVP 2023 Report Share Posted January 20, 2018 There is an example of the Unitronics alarm manager under Help->Examples->Version 900 -> Project examples -> ladder -> V1040 Alarm Example.vlp. The Unitronics alarm manager is a bit of a complicated beast for someone new to the product; you may be better off making your own alarm handler in logic depending on what your needs are. Can you describe what you want to do? Joe T. Quote Link to comment Share on other sites More sharing options...
t0r3r0s Posted January 20, 2018 Author Report Share Posted January 20, 2018 10 minutes ago, Joe Tauser said: There is an example of the Unitronics alarm manager under Help->Examples->Version 900 -> Project examples -> ladder -> V1040 Alarm Example.vlp. The Unitronics alarm manager is a bit of a complicated beast for someone new to the product; you may be better off making your own alarm handler in logic depending on what your needs are. Can you describe what you want to do? Joe T. I need alarm screen on hmi , where i can find allarm history , and can i on unitronics do something like this : when alarm is activate example security circuit is broken down , i need pop up with message circuit is broken ? i have one more question about indirect function on photo you can see my leader diagram http://pokit.org/get/?4e32ee4c563cefb6ee9722e39481ef5f.jpg http://pokit.org/get/?63103df24bd0eacbb2befc9000babcf2.jpg http://pokit.org/get/?0c66c4829007019b5e5e2c57421ae8e4.jpg why dont load hmi screen when timers are on ? you can see on photo 1 and 3 diagram on photo two are timers one more questions here if you see on select day of month when i select 20 day day 1 is automatic on why ??? Quote Link to comment Share on other sites More sharing options...
MVP 2023 Joe Tauser Posted January 20, 2018 MVP 2023 Report Share Posted January 20, 2018 The Alarm manager will do what you're asking - it's configured in the tree on the right in Visilogic. Read all the Help on Alarms before you dive into it. Photo 1 - you have the same register for Month and Day. These should be different. When you go online, what values do they contain? Photo 2 - a very nice screen but I have no idea what's under the hood Photo 3 - I don't see a timer. That logic will call a display once, as the coil triggering the transition is hanging on the power rail. Is the rail in a subroutine? Joe T. Quote Link to comment Share on other sites More sharing options...
t0r3r0s Posted January 20, 2018 Author Report Share Posted January 20, 2018 28 minutes ago, Joe Tauser said: The Alarm manager will do what you're asking - it's configured in the tree on the right in Visilogic. Read all the Help on Alarms before you dive into it. Photo 1 - you have the same register for Month and Day. These should be different. When you go online, what values do they contain? Photo 2 - a very nice screen but I have no idea what's under the hood Photo 3 - I don't see a timer. That logic will call a display once, as the coil triggering the transition is hanging on the power rail. Is the rail in a subroutine? Joe T. ok i make mistake on photo one , but i have this problem on photo one you can see day of month isnt on why ??? on photo two you see what i set on my plc on photo 3 are my definition of day of month http://pokit.org/get/?f08eb856ab7f8cded373411b2a4ee7f5.jpg http://pokit.org/get/?c44d1571d8c8a67db5deb6be38915e8b.jpg http://pokit.org/get/?6c12be8aeb7494e0ae77edf287327d5e.jpg Quote Link to comment Share on other sites More sharing options...
MVP 2023 Joe Tauser Posted January 20, 2018 MVP 2023 Report Share Posted January 20, 2018 It's hard to troubleshoot a program without all the information. What are the online values of MI 57, MI 58, ML 81, and ML 80? Joe T. Quote Link to comment Share on other sites More sharing options...
t0r3r0s Posted January 20, 2018 Author Report Share Posted January 20, 2018 2 minutes ago, Joe Tauser said: It's hard to troubleshoot a program without all the information. What are the online values of MI 57, MI 58, ML 81, and ML 80? Joe T. M57 is time for "start obavijesti" M58 is time for "Stop obavijesti" ML81 is day of month and ML 80 is month i have only problem with days Quote Link to comment Share on other sites More sharing options...
