Good Morning All,
I'm having a little difficulty with magnetic pickups.  I have a V700  With the expansion adapter and two modules - the IO AI8 and a DI8 R04.  I have an external 2-wire magnetic pickup that generates a sine wave Frequency with an amplitude of 1V+/- Based on the flow through a pipe with a turbine in it.  In the wiring diagram, each counter/frequency shows a minimum of three wires at the pickup.  Looking for guidance for how to wire this module in with the two wire pickup as described above...  Any help is appreciated
