Arvid Samnoy Posted February 2, 2018 Report Share Posted February 2, 2018 I have connected the 24V to respective 1 and 0V. A constant red light showing on the module. I replaced the unit with a new one, same result. Unable to get the valves to function. Quote Link to comment Share on other sites More sharing options...
Ofir Posted April 25, 2018 Report Share Posted April 25, 2018 Hello Arvid, As I remember we discussed this case before and the issue was that the connector was not sitting properly. Quote Link to comment Share on other sites More sharing options...
Ederson Oss Emer Posted January 12, 2020 Report Share Posted January 12, 2020 I have the same problem. Have voltage (24Vcc) but two modules UIA-0006 dosen't work. A constant red light showing on the module. I have other modules (UIA-0008/UIA0402) but only the UIA-0006 happened this problem. Quote Link to comment Share on other sites More sharing options...
