Artur Posted February 6, 2018 Report Share Posted February 6, 2018 Hi all! I have an Vision230 controller I wrote an app and I need to set some parameters on HMI. Here is the variable setting. The problem is: on Display don't apear any data or cursor to change my data. Maybe I do something wrong? How do I access and change it? Quote Link to comment Share on other sites More sharing options...
Artur Posted February 6, 2018 Author Report Share Posted February 6, 2018 Ok! I solved a half of the problem. There I used ladder display call, I changed it to display links jump conditions and cursor apeared. another problem when I change one parameter press "Enter" the cursor goes to the next parameter, but at the last parameter it is gone and I need to change displays to return the cursor. What problem can be now? Quote Link to comment Share on other sites More sharing options...
MVP 2023 Joe Tauser Posted February 7, 2018 MVP 2023 Report Share Posted February 7, 2018 Reset SB 30 to re-enable the variable entry. Joe T. Quote Link to comment Share on other sites More sharing options...
