GonzaloRoldan_ Posted February 15, 2018 Report Share Posted February 15, 2018 Hi everyone! Today I opened a project with VisiLogic, and it's the first time that when the VisiLogic was loading, it appeared a message saying that "The project contains a section that must be defragmented".. After a few seconds everything was normal.. What about that message? What does it means? Thanks! Gonzalo Quote Link to comment Share on other sites More sharing options...
MVP 2023 Flex727 Posted February 15, 2018 MVP 2023 Report Share Posted February 15, 2018 After repeated editing and saving of a VisiLogic project, it can get fragmented and needs to be rearranged. This is not unlike what can happen to a hard drive. It is perfectly normal and won't cause any problems except for the occasional delay when opening a fragmented project. 1 Quote Link to comment Share on other sites More sharing options...
GonzaloRoldan_ Posted February 15, 2018 Author Report Share Posted February 15, 2018 Thanks Flex!! It's good to know that it won't cause any problems.. Cheers, Gonzalo Quote Link to comment Share on other sites More sharing options...
MVP 2023 Flex727 Posted February 15, 2018 MVP 2023 Report Share Posted February 15, 2018 By the way, you can manually check for the need for defragmentation and take care of it, if needed, before you save. You can find the item under the Build menu. I rarely bother though. 1 Quote Link to comment Share on other sites More sharing options...
