david avran Posted February 18, 2018 Report Share Posted February 18, 2018 when I run online test my out puts don't light up red. I have power flow up to the output Quote Link to comment Share on other sites More sharing options...
MVP 2023 Ausman Posted February 18, 2018 MVP 2023 Report Share Posted February 18, 2018 This sounds like they are in a subroutine that you haven't called. Utils/Call/Call Subroutine. etc cheers, Aus Quote Link to comment Share on other sites More sharing options...
Cam Posted February 18, 2018 Report Share Posted February 18, 2018 Did you us a direct coil more than once for that output? Or is the output ina subroutine which is not being called? Quote Link to comment Share on other sites More sharing options...
david avran Posted February 18, 2018 Author Report Share Posted February 18, 2018 Yea I had multi output of the same output on my ladder I figured it out thank you still learning how to this Quote Link to comment Share on other sites More sharing options...
