HexMan Posted February 26, 2018 Report Share Posted February 26, 2018 Hi to everyone! I´m new in the forum and with this type of divices. I have a problem with Drum Secuencers, in the first configuration works fine, but when I make a change (times or another) no change the real function, time... Any idea?? Quote Link to comment Share on other sites More sharing options...
MVP 2023 Ausman Posted February 26, 2018 MVP 2023 Report Share Posted February 26, 2018 Hi Hex, In case you haven't got this info, here is the Drum help as a pdf. It is normally found in Help under Function Blocks. For each Drum you use, you need a separate initialisation/configuration. It sounds like you may not have done this. cheers, Aus Drum.pdf Quote Link to comment Share on other sites More sharing options...
HexMan Posted February 27, 2018 Author Report Share Posted February 27, 2018 Thanks Ausman for your reply. The problem is with only 1 drum, my program is only 1 drum, all works fine, the problem is when I make a change (step time, for example). Downloading the software again the time not is modified... Quote Link to comment Share on other sites More sharing options...
MVP 2023 Ausman Posted February 27, 2018 MVP 2023 Report Share Posted February 27, 2018 Hmmm. I have never had that issue. But whenever I have changed a drum parameter, it is always done as new program name. I do a compile, and then if ok I save as a different name and then do the download. (No matter how small a change, I always do sequential program saves so that I can always reference something older if needed.) Maybe this is the issue if you are simply changing numbers? Have you also tried an Initialise and Reset via Connection/Communication & OS/2nd tab/Bottom right? Perhaps the PLC needs an initialise to get things working correctly. FYI, I also draw your attention to the way I use drum. They are always an occasional part of the process, only called when needed. My method is to have some, or all of the times as the maximum allowed, with triggers derived from the program that will force a step increase if the current step has been performed correctly/enough. This way the drum is active only as long as necessary. My physical conditions can vary significantly, with unusual hiccouphs in the process meaning the "master" timeout for each step is a must, essentially forcing things along to eventually end the drum or sometimes do it all again. So my drum use is a little different to the way it is really intended. cheers, Aus Quote Link to comment Share on other sites More sharing options...
HexMan Posted February 28, 2018 Author Report Share Posted February 28, 2018 Thanks Ausman for reply. The problem was that it did not reset when downloading the new program to the OPLC. SOLVED! Thank you very much, see you again (SURE!). Quote Link to comment Share on other sites More sharing options...
