Arnor Posted February 27, 2018 Report Share Posted February 27, 2018 Hi, I have a V700 that has few trends on display. Randomly the trends goes black and the line disappears, and you cant see anything. If I press the "M" button the trend line that disappear is back. Its is very annoying because we need to see the trend and we have to log on to the V700 and press the "M" button to see it. Any idea why this happens? See attachment. Quote Link to comment Share on other sites More sharing options...
Arnor Posted April 5, 2018 Author Report Share Posted April 5, 2018 Can you please approve this post dear moderator Quote Link to comment Share on other sites More sharing options...
MVP 2023 Flex727 Posted April 5, 2018 MVP 2023 Report Share Posted April 5, 2018 3 minutes ago, Arnor said: Can you please approve this post dear moderator I think this post was approved back in February. Regarding your problem, as I'm sure you know, the "M" button toggles between online and history mode. Are you saying the trend line disappears but when you toggle the "M" button twice that data that wasn't there before suddenly appears? If so, I've never seen that before. Someone is probably going to have to look at your program to diagnose. You may need to send it to Unitronics Support. Quote Link to comment Share on other sites More sharing options...
stembera Posted April 27, 2018 Report Share Posted April 27, 2018 Hello Arnor! Do you observe this behavior directly on display of PLC or via the Remote Operator? I have the same problem with V1040 when connecting via Remote Operator. Please see my post in the Remote Operator section (trend object only partly visible). I hope we will find the solution. regards, Michal. 1 Quote Link to comment Share on other sites More sharing options...
Arnor Posted May 22, 2018 Author Report Share Posted May 22, 2018 On 4/5/2018 at 5:12 PM, Flex727 said: I think this post was approved back in February. Regarding your problem, as I'm sure you know, the "M" button toggles between online and history mode. Are you saying the trend line disappears but when you toggle the "M" button twice that data that wasn't there before suddenly appears? If so, I've never seen that before. Someone is probably going to have to look at your program to diagnose. You may need to send it to Unitronics Support. Hi Flex, Yes this is exactly what happens. I can see the data when I press the "M" button. I am not sure if this is doing something with the memory of the trend, but I am not saving data to the SD card. On 4/27/2018 at 8:10 PM, stembera said: Hello Arnor! Do you observe this behavior directly on display of PLC or via the Remote Operator? I have the same problem with V1040 when connecting via Remote Operator. Please see my post in the Remote Operator section (trend object only partly visible). I hope we will find the solution. regards, Michal. Hi Michal! I am using Remote Operator but I have not checked if this is also in the PLC display too, will do that next time. But thank you for linking your post. I am going to test the Remote Access program and see if it changes anything. Cheers. Arnor Quote Link to comment Share on other sites More sharing options...
MVP 2023 Ausman Posted May 29, 2018 MVP 2023 Report Share Posted May 29, 2018 For Michal and Arnor, another unlikely possibility for you to consider. Quite by accident I discovered that my A/V program has placed some Unitronics programs into the "I don't fully trust this program" areas of it's firewall. It has never upset my comms at all, so I am not changing it, but just wondering if your issues might be somehow related to what your A/V has done in regards to Rem Op. Cheers, Aus Quote Link to comment Share on other sites More sharing options...
Arnor Posted November 19, 2018 Author Report Share Posted November 19, 2018 Hi I finally went to the place and checked on the PLC and the remote operator software. It seems to be some kind of bug on the Remote Operator. Quote Link to comment Share on other sites More sharing options...
MVP 2023 Ausman Posted November 19, 2018 MVP 2023 Report Share Posted November 19, 2018 Before I found this post I followed up on a private message with Arnor & Stembera, suggesting how to go about contacting support about this issue. We'll wait and see what happens, unless someone has some fresh thoughts on why it occurs. Edit As it is happening at the plc and not just during remote work, it is likely a bug. I incorrectly interpreted the photos in the message.....had what they were back to front. Bug is in RO. cheers, Aus Quote Link to comment Share on other sites More sharing options...
Saragani Posted November 20, 2018 Report Share Posted November 20, 2018 Unless I have a specific scenario how to reproduce the problem, then I can't fix it in Remote Operator. Quote Link to comment Share on other sites More sharing options...
Arnor Posted November 20, 2018 Author Report Share Posted November 20, 2018 3 hours ago, Saragani said: Unless I have a specific scenario how to reproduce the problem, then I can't fix it in Remote Operator. I can give you the program if you want, or remote access. If that helps. I know that if I press the "M" button I can see the rest of the graph. I know that the problem is on multiply computers, even with fresh install of remote operator, the lines disappear exactly same between computers. Using remote on Visilogic does not show this problem. See pictures: Quote Link to comment Share on other sites More sharing options...
MVP 2023 Ausman Posted November 20, 2018 MVP 2023 Report Share Posted November 20, 2018 Just asking, is Remote Operator installed as admin, and is also running as administrator? cheers, Aus Quote Link to comment Share on other sites More sharing options...
Saragani Posted November 20, 2018 Report Share Posted November 20, 2018 OK @Arnor, please give me the program, and I'll try to reproduce it. It's weird that the problem does not reproduce in VisiLogic, since both are based on the same code. I wrote most of the code of enhanced PLCs Remote Access in VisiLogic, and most of the code of Remote Operator, so I'm familiar with it, and can't understand how something like this can happen. You can send the project to support@unitronics.com, and ask them to forward it to me. Also instruct me to which screen to enter, or what to do in order to reproduce the problem. Thanks. 1 Quote Link to comment Share on other sites More sharing options...
Saragani Posted November 22, 2018 Report Share Posted November 22, 2018 @Arnor, did you pass the project to our support? Quote Link to comment Share on other sites More sharing options...
Arnor Posted November 22, 2018 Author Report Share Posted November 22, 2018 @Saragani Hi sorry for the delay, its finals at my university and I was bit busy. I just sent support email with my program. Thank you very much for this. Cheers. Quote Link to comment Share on other sites More sharing options...
Saragani Posted November 22, 2018 Report Share Posted November 22, 2018 @Arnor, I think I've found the problem. Take the dll below and overwrite the one that exists in your installation folder. Make sure to create a backup of the original dll first. Please update me if it helps. Thanks. Unitronics.RemoteOperator.dll 3 Quote Link to comment Share on other sites More sharing options...
Arnor Posted November 22, 2018 Author Report Share Posted November 22, 2018 @Saragani FIXED! Thank you very much for this, I tested the file and it works perfectly. See the snapshot, one is with the file, the other is not. What was the bug? running out of memory somewhere? Again, thank you all for your help and Saragani for fixing the problem. Cheers! 1 Quote Link to comment Share on other sites More sharing options...
MVP 2023 Ausman Posted November 22, 2018 MVP 2023 Report Share Posted November 22, 2018 A great solution to the issue. Saragani, is this dll used by Remote Access? After correctly applying the new dll, Remote Access screens now transition to the next screen completely OK on a 120 connected via unican from a 130. Previously when shifting screens there would be a "broken up" sort of image that appeared to be the program "building" the new screen, where part of the screen was the new one and part was the old. It would clear up to the new screen after a few seconds. I always put this down to a bandwidth/speed issue.....but perhaps it has also been cured? cheers, Aus Quote Link to comment Share on other sites More sharing options...
Saragani Posted November 23, 2018 Report Share Posted November 23, 2018 18 hours ago, Arnor said: What was the bug? running out of memory somewhere? No, just a typo. Quote Link to comment Share on other sites More sharing options...
Saragani Posted November 23, 2018 Report Share Posted November 23, 2018 16 hours ago, Ausman said: A great solution to the issue. Saragani, is this dll used by Remote Access? After correctly applying the new dll, Remote Access screens now transition to the next screen completely OK on a 120 connected via unican from a 130. Previously when shifting screens there would be a "broken up" sort of image that appeared to be the program "building" the new screen, where part of the screen was the new one and part was the old. It would clear up to the new screen after a few seconds. I always put this down to a bandwidth/speed issue.....but perhaps it has also been cured? cheers, Aus No, it is being used by Remote Operator only, and it fixes just the trend issue. 1 Quote Link to comment Share on other sites More sharing options...
MVP 2023 Ausman Posted November 23, 2018 MVP 2023 Report Share Posted November 23, 2018 7 hours ago, Saragani said: No, it is being used by Remote Operator only Ohh well, just an amazing coincidence. But the problem has definitely gone away, even during really slow transitions due to heavy net usage at the remote end. cheers, Aus Quote Link to comment Share on other sites More sharing options...
