HST-Heuer Posted February 27, 2018 Report Share Posted February 27, 2018 Dear colleagues, i need some support concerning the remote control with an iPhone. My connection is not really stable. I connect the iPhone and after 10-60 seconds the connection fail and I cannot connect to the PLC anymore. So I have to disconnect to the WLAN connection and connect ones more and then it goes, but again only 10-60 seconds. So the question is whether it is an iPhone problem or a general problem with the connection. Or do i have to change the router adjustments? Another oddness is that it is only possible to connect if the IP adress is 192.168.1.1 and this is the same as the router ones. it is a riddle to me how this works. Maybe I need an iOS update? I am thankful for every guess. Best regards Fabian Quote Link to comment Share on other sites More sharing options...
MVP 2023 Flex727 Posted February 27, 2018 MVP 2023 Report Share Posted February 27, 2018 Post your program. Quote Link to comment Share on other sites More sharing options...
MVP 2023 Joe Tauser Posted March 1, 2018 MVP 2023 Report Share Posted March 1, 2018 On 2/27/2018 at 11:47 AM, Flex727 said: Post your program. That, and try setting SI 101 (TCP timeout) to 10. What is the model number of your PLC? Joe T. Quote Link to comment Share on other sites More sharing options...
HST-Heuer Posted March 5, 2018 Author Report Share Posted March 5, 2018 Quote Link to comment Share on other sites More sharing options...
HST-Heuer Posted March 5, 2018 Author Report Share Posted March 5, 2018 Hey Joe, it was a good idea, but it works only a little bit better. Quote Link to comment Share on other sites More sharing options...
HST-Heuer Posted March 5, 2018 Author Report Share Posted March 5, 2018 Hello, I found my fault. I had to change the Ethernet settings of the PLC. It was 192.168.1.1 by dafault, but my Router has the same IP adress. Now everythin is fine. Thanks! Quote Link to comment Share on other sites More sharing options...
MVP 2023 Flex727 Posted March 5, 2018 MVP 2023 Report Share Posted March 5, 2018 Thanks for reporting back your findings! Quote Link to comment Share on other sites More sharing options...
MVP 2023 Joe Tauser Posted March 7, 2018 MVP 2023 Report Share Posted March 7, 2018 Glad you figured it out. I've never made a mistake like that. BTW, posting pictures of function blocks that contain information with out posting the corresponding dialog boxes does not count as posting your program. For you other readers out there, if you upload your .vlp file we can take a look inside things like the TCP/IP CARD INIT block and be much more helpful in solving the problem. Joe T. Quote Link to comment Share on other sites More sharing options...
