Attila Zsigri Posted March 1, 2018 Report Share Posted March 1, 2018 Hi, I'm having issues with Jazz JZ20-j-T40 OPLC USB driver under Windows 7 Enterprise 64bit. I installed the USB drivers, but the system doesn't recognize the device (Unknown device, : error code 43). Does someone have solution? Thanks for your help! Quote Link to comment Share on other sites More sharing options...
MVP 2023 Ausman Posted March 1, 2018 MVP 2023 Report Share Posted March 1, 2018 Have a good read through this topic and references therein for some pointers that might help: You may also be running into problems with 32 bit drivers going onto 64. cheers, Aus Quote Link to comment Share on other sites More sharing options...
