jnm Posted March 5, 2018 Report Share Posted March 5, 2018 I have an application in which I'm trying to utilize the "SD Card Explorer Lite" in Visual Studio. I'm getting an error when debugging the application. See attached document. The application is as downloaded from Unitronics. Seems the error is linked to the "Unitronics.ComConfig.Lite.dll". Visual Studio 2017 Windows 7 [64-bit] SD Card Explorer Lite error.docx Quote Link to comment Share on other sites More sharing options...
Saragani Posted March 6, 2018 Report Share Posted March 6, 2018 Is it the SD Card Explorer lite code example, or your own code? If it's your own code, and the example runs fine, then I'll need your project (I tried reproducing the issue with the code example on Visual studio 2017). Quote Link to comment Share on other sites More sharing options...
jnm Posted March 7, 2018 Author Report Share Posted March 7, 2018 It is the SD Card Explorer lite code example. Quote Link to comment Share on other sites More sharing options...
Saragani Posted March 8, 2018 Report Share Posted March 8, 2018 And it works perfectly fine here on Visual Studio 2017 (I ran it in Any CPU Mode, although it is supposed to run in x86, since the .Net communication driver is usually compiled as such). Can you zip your entire solution project and upload it to this forum? I want to see that it fails here if I run the exe, I want to look at the App Config file (Visual Studio must have created one), and I want to also debug it (if needed) with an external debugger (without recompiling the code with VS2017) Quote Link to comment Share on other sites More sharing options...
