leen Posted March 21, 2018 Report Share Posted March 21, 2018 Hello, I want to get a table where I put in parameter settings. On the first colum I put in the name of parameter. On the second the value of the parameter is read. Now I will not have the possibility that the name of the parameters are changed. So colum 1 read only. At colum 2 I will have the possibility to change the settings. But on the table only both colums are ready only or editable. Can somebody help me how to read out a parameterlist on the way I wanted? Thanks Leen Quote Link to comment Share on other sites More sharing options...
Nanashi Posted March 22, 2018 Report Share Posted March 22, 2018 23 hours ago, leen said: Hello, I want to get a table where I put in parameter settings. On the first colum I put in the name of parameter. On the second the value of the parameter is read. Now I will not have the possibility that the name of the parameters are changed. So colum 1 read only. At colum 2 I will have the possibility to change the settings. But on the table only both colums are ready only or editable. Can somebody help me how to read out a parameterlist on the way I wanted? Thanks Leen Hello Leen, You could try with Message Composer, I think it is not the best way to do such things, but I can't think of a better way. You can see the example "Log to File" in UserLogs folder. Quote Link to comment Share on other sites More sharing options...
