Cara Bereck Levy Posted August 17, 2020 Report Share Posted August 17, 2020 OH--I NEEDED THAT!!! LOLOLOLOLOL!!!! On 8/16/2020 at 2:46 AM, Ausman said: Joe, do you mean like this? cheers, Aus Quote Link to comment Share on other sites More sharing options...
Cara Bereck Levy Posted August 17, 2020 Report Share Posted August 17, 2020 Hi @Prem Lanka, Was that Israel Support? Please contact them again if you have difficulties; I saw that you originally posted on Friday, which is our weekend, but everyone is back at work on Sunday 🙂 On 8/14/2020 at 4:44 PM, Prem Lanka said: Support said that it is common for CPUs to lose connection with the Panel immediately after applying a firmware update, and that just cycling the power should fix the problem. However, cycling the power did not fix the connection issue, and my ip settings still would not save so I could not ping it from any other device. I did eventually get it to work after performing the following: Quote Link to comment Share on other sites More sharing options...
Cam Posted August 17, 2020 Report Share Posted August 17, 2020 @Prem Lanka What is all connected to the system for IO and other devices? Quote Link to comment Share on other sites More sharing options...
MVP 2023 Joe Tauser Posted August 17, 2020 MVP 2023 Report Share Posted August 17, 2020 🤣 Yes. Yes, I do! I like how I'm the Scarecrow. If I only had a brain...... Joe T. Quote Link to comment Share on other sites More sharing options...
MVP 2014 Simon Posted August 19, 2020 MVP 2014 Report Share Posted August 19, 2020 Ha Ha, love the image 🙂 Quote Link to comment Share on other sites More sharing options...
greml1n Posted February 26, 2021 Report Share Posted February 26, 2021 Currently have an email in to support but figured I’d try here too. I have been experiencing the CPU Error message occasionally on a couple Unistream 15”. Customer says it’s happened 4x over a few months. It would be great to know why it happens but it seems pretty random. I was wondering what the sequence of operations is when it occurs. There are the three choices of reboot, ignore, or switch to run mode. What mode is it in when the message appears? I would assume stop mode but Pump still runs in my application. Is the Unistream awaiting a choice of the three options or will it eventually revert to stop mode after a certain time? All of my firmware is correct with the Unilogic software btw. The two units that have been exhibiting this error are using version 1.28.34 and 1.26 Quote Link to comment Share on other sites More sharing options...
jj168 Posted June 11, 2022 Report Share Posted June 11, 2022 On 3/29/2018 at 5:31 PM, EduMarg said: Scott, I sent you an email with answer and solution. Best regards Hi, hope please sent me the way to fix the problem. Quote Link to comment Share on other sites More sharing options...
Rivka Posted June 29, 2022 Report Share Posted June 29, 2022 Hi @jj168, Please contact support. There is no one "magic" way to solve that issue. CPU error can come from a lot of reasons. Hope you'll get the solution very soon. Quote Link to comment Share on other sites More sharing options...
