salahedine zidouh Posted April 3, 2018 Report Share Posted April 3, 2018 hello im new in visilogic i want to add a counter i have two compressor so i want to know how much time each compressor work im glad for you'r support Quote Link to comment Share on other sites More sharing options...
MVP 2023 Flex727 Posted April 3, 2018 MVP 2023 Report Share Posted April 3, 2018 I don't think you really need a Counter for this. Just use the Increment function of an MI, ML, or DW (depending on the max value anticipated) triggered off SB 3 to count seconds. If you expect a total run time of less than 24 hours, you can actually use a Timer so that you can display it on the HMI easily. Quote Link to comment Share on other sites More sharing options...
