Fahrphrompuken Posted April 5, 2018 Report Share Posted April 5, 2018 When using graphic objects from the path C:\Program Files (x86)\Unitronics\Unitronics VisiLogic_C\Data\ImagesC\UniPics\Medium\Pipes - Indexed Medium, there are only elbows that face left and down. There seems to be no way to flip, or rotate to use them in other directions. If I try to edit one and rotate it in MS Paint, it shows up with the Uni-logo and X pattern. Is there a way to manipulate the direction of the image in Visilogic, or to edit the graphic so that it displays as it is supposed to in the HMI? I am creating the HMI for a V1210. Quote Link to comment Share on other sites More sharing options...
MVP 2023 Flex727 Posted April 5, 2018 MVP 2023 Report Share Posted April 5, 2018 5 minutes ago, Fahrphrompuken said: If I try to edit one and rotate it in MS Paint, it shows up with the Uni-logo and X pattern. What I do is place the object on an HMI screen in VisiLogic, screen capture, place in Paint, crop, and rotate/manipulate as needed. It's a bit of a pain, but it works. Quote Link to comment Share on other sites More sharing options...
Fahrphrompuken Posted April 5, 2018 Author Report Share Posted April 5, 2018 Thanks for the tip. That worked pretty well. Quote Link to comment Share on other sites More sharing options...
