Interroga Posted April 5, 2018 Report Share Posted April 5, 2018 i have problems with unilogics 1.23.25 where open for work. I execute Unilogic Diagnostics and show me all normal. I try open and two seconds after it close , without notifier information. I don't have anti-virus in my computer. I need help for discover what cause this problem. Regards , Mauro . Quote Link to comment Share on other sites More sharing options...
Saragani Posted April 6, 2018 Report Share Posted April 6, 2018 are older versions work? Quote Link to comment Share on other sites More sharing options...
Interroga Posted April 7, 2018 Author Report Share Posted April 7, 2018 yes! i discover the problem. This problem is in user. This software not work in all user the computer. After two days , trying all solutions , by chance.... work. thanks for your reply. regards, mauro. Quote Link to comment Share on other sites More sharing options...
Saragani Posted April 7, 2018 Report Share Posted April 7, 2018 What do you mean by "This software not work in all user"? The program does run as Admin (as for this version. Next release will run as standard user), and it runs on the current user that runs the software. If the folder c:\ProgramData\Unitronics\UniLogic does not have full access to all users, then this could be a problem (Next version installer should set this folder with full access to "Everyone"), But this usually happens only when UniLogic is not being ran as Admin (which is not the case in 1.23.25) Can you please describe the problem and the solution, so other people will have a solution, in case they encounter the same problem? Quote Link to comment Share on other sites More sharing options...
Interroga Posted May 7, 2018 Author Report Share Posted May 7, 2018 I've seen all the settings, but found no limitation on the users. I still use the program with another user on my pc and live normally. Sorry for not putting any new information in order to fix it. Thanks again for always help us. Mauro Quote Link to comment Share on other sites More sharing options...
