stembera Posted April 18, 2018 Report Share Posted April 18, 2018 Hello world, connected to a remote PLC via Remote Operator, the object "trend" is often not displayed correctly. Only a part of the curves on the right side of the object are visible. Left part is invisible and can be displayed only by clicking the "M" button. Did you observe similar behavior of the trend object? Is it possible to get rid of this phenomenon? Thanks, Michal. Quote Link to comment Share on other sites More sharing options...
MVP 2023 Ausman Posted April 18, 2018 MVP 2023 Report Share Posted April 18, 2018 Hmmm. More of that "fun" of yours, Michal! And I don't know the answer, either. cheers, Aus Quote Link to comment Share on other sites More sharing options...
MVP 2023 Ausman Posted April 30, 2018 MVP 2023 Report Share Posted April 30, 2018 Michal, further to your "bump" elsewhere, just wondering if the same thing happens using Remote Access, instead of Remote Op? cheers, Aus Quote Link to comment Share on other sites More sharing options...
stembera Posted May 3, 2018 Author Report Share Posted May 3, 2018 Thank you Ausman for the idea. I will try Remote Access when the problem appears again. I will give you a feedback. Quote Link to comment Share on other sites More sharing options...
Saragani Posted November 22, 2018 Report Share Posted November 22, 2018 @stembera, the problem was also reported here: If the issue still reproduces on your computer, can you please check it with the DLL on that thread, and update me? Thanks 1 Quote Link to comment Share on other sites More sharing options...
