wawa Posted April 24, 2018 Report Share Posted April 24, 2018 i have a machine that work good few month with v570 hmi and snap i/o module V200-18-E3XB and expansion EX-D16A3-RO8 module but now the machine was stoped i mean the i/o of expansion was work corectly but the snap i/o dont work propebly i mean in snap i/o module the analuge input and analoge output work put digital input and output dont work. when i test input/output in info mode they work corectly but in application they dont i dont know what happer Quote Link to comment Share on other sites More sharing options...
MVP 2023 Joe Tauser Posted April 25, 2018 MVP 2023 Report Share Posted April 25, 2018 Look at the data sheet for the -E3XB and make sure you have +24V and 0V present in the right places. It sounds like you've lost one or the other. Joe T. Quote Link to comment Share on other sites More sharing options...
wawa Posted April 25, 2018 Author Report Share Posted April 25, 2018 first thanks for your response have 24v+ and 0v present in there place but the same probleme any other idea please Quote Link to comment Share on other sites More sharing options...
MVP 2023 Flex727 Posted April 25, 2018 MVP 2023 Report Share Posted April 25, 2018 Sometimes the Snap-In modules can come loose or the contacts can wear in high vibration environments. Try removing the module carefully and replacing it firmly, making sure it's well-seated. Quote Link to comment Share on other sites More sharing options...
Gabriel Franco Posted April 25, 2018 Report Share Posted April 25, 2018 If you tested your I/O using INFO (Assuming you forced outputs and check input status) mode and worked properly as you stated, then it must be a programming issue. Quote Link to comment Share on other sites More sharing options...
Yasir Posted March 7, 2020 Report Share Posted March 7, 2020 What is meaning of emergency stop Sq fault in plc 32 red light Quote Link to comment Share on other sites More sharing options...
