Float values with modbus
Hello,
I am developping an application that uses Bronkhorst mass flow controllers with modbus communication. Some years later, I used a vision V570 with success. This time, I am using an Unistream and reading floats with modbus doesn't work properly : the 2 registers are inverted so the value is wrong. I tried to revert the register by using buffers and it works perfectly for read values but values to be written are rounded so I can't send setpoint to my controllers. Does anyone have an explanation ?
Below is a snapshot of the conversion code :
  • 5 years later...
Hello,
I am new to Modbus programming and would like to ask for advice on the above topic.
In my application I should write a decimal number into a register of a Danfoss control valve.
What is the best way to convert a REAL value to a UINT?
Below is my first draft, but I get a status error. Can someone explain to me what I did wrong?
