C_R_PLC Posted May 31, 2018 Report Share Posted May 31, 2018 Title basically says the whole issue. I'm trying to get a usable reading from the sensor listed below, but it just seems to fluctuate between 2 and 3 volts even if nothing is plugged in. So my question is two-fold. Can I get a signal that is more precise than a whole number, and will that sensor even work with a PLC and if not is there anything I can get to interface the two? Sensor - https://www.dfrobot.com/wiki/index.php/Turbidity_sensor_SKU:_SEN0189 Thank you very much for your time/help. Quote Link to comment Share on other sites More sharing options...
MVP 2023 Flex727 Posted May 31, 2018 MVP 2023 Report Share Posted May 31, 2018 According to your link, the sensor output is only 0-4.5 volts. However, you should be able to make that work. The standard analog input on hte V350-35-RA22 has 14-bit resolution, which even at half scale will still give you at least 2 or 3 decimal places of precision. How are you measuring the 2-3 volts you say you are getting? Is this a direct measurement with a voltmeter, or are you linearizing the analog input on the PLC? Quote Link to comment Share on other sites More sharing options...
PA_DB Posted May 31, 2018 Report Share Posted May 31, 2018 If you have access to a 0-10V source you can inject a signal and see if it is a code/config issue or the device. Ramping up and down the scale will give you a change in your PLC value. In the absence of a source you can even use batteries 1.5/3V/6V/9V Some likely things to check: Dip switch settings are correct as per install manual for 0-10V Hardware config settings are right Any scaling in your code is correct for the bit resolution of your model 0V connections as per manual The help files and examples are always worth looking at Quote Link to comment Share on other sites More sharing options...
C_R_PLC Posted May 31, 2018 Author Report Share Posted May 31, 2018 1 hour ago, Flex727 said: According to your link, the sensor output is only 0-4.5 volts. However, you should be able to make that work. The standard analog input on hte V350-35-RA22 has 14-bit resolution, which even at half scale will still give you at least 2 or 3 decimal places of precision. How are you measuring the 2-3 volts you say you are getting? Is this a direct measurement with a voltmeter, or are you linearizing the analog input on the PLC? Direct reading through the MI that the analog input is going to. No matter what I do it only gives whole value readings of 1-4. 41 minutes ago, PA_DB said: If you have access to a 0-10V source you can inject a signal and see if it is a code/config issue or the device. Ramping up and down the scale will give you a change in your PLC value. In the absence of a source you can even use batteries 1.5/3V/6V/9V Some likely things to check: Dip switch settings are correct as per install manual for 0-10V Hardware config settings are right Any scaling in your code is correct for the bit resolution of your model 0V connections as per manual The help files and examples are always worth looking at I've checked all that a few times now, I'm just trying to test this sensor so there isn't much actual logic involved. Jumpers are all correct and all that. Quote Link to comment Share on other sites More sharing options...
C_R_PLC Posted May 31, 2018 Author Report Share Posted May 31, 2018 Ignore the second one, that was just me testing if it was the analog input itself, it's exactly the same. Quote Link to comment Share on other sites More sharing options...
MVP 2023 Flex727 Posted May 31, 2018 MVP 2023 Report Share Posted May 31, 2018 2 hours ago, C_R_PLC said: Direct reading through the MI that the analog input is going to. No matter what I do it only gives whole value readings of 1-4. That's basically zero. The value you should see on the MI is 0-16,383, which is scaled to 0-10V (i.e. 1V = 1638, 5V = 8191, 10V = 16383). Quote Link to comment Share on other sites More sharing options...
MVP 2023 Ausman Posted May 31, 2018 MVP 2023 Report Share Posted May 31, 2018 4 hours ago, C_R_PLC said: Direct reading through the MI that the analog input is going to. No matter what I do it only gives whole value readings of 1-4. Yes....but what is the actual reading at the connections at the plc using a voltmeter? As Flex says, the MI0 is essentially indicating nothing is there at all. As C_R says, check connections, especially that your 0V are commoned correctly. cheers, Aus Quote Link to comment Share on other sites More sharing options...
MVP 2023 Ausman Posted June 1, 2018 MVP 2023 Report Share Posted June 1, 2018 9 hours ago, C_R_PLC said: No matter what I do it only gives whole value readings of 1-4 And visiting this again, I think I see where your fundamental thinking is astray. I have a feeling that you are expecting to see MI0 showing the actual voltage. It doesn't work that way, it works the way Flex has pointed out in that analogue inputs generate numbers b/n a range, dependent on speed of read and type of input. And I still want you to use a voltmeter! cheers, Aus Quote Link to comment Share on other sites More sharing options...
C_R_PLC Posted June 1, 2018 Author Report Share Posted June 1, 2018 9 hours ago, Ausman said: And visiting this again, I think I see where your fundamental thinking is astray. I have a feeling that you are expecting to see MI0 showing the actual voltage. It doesn't work that way, it works the way Flex has pointed out in that analogue inputs generate numbers b/n a range, dependent on speed of read and type of input. And I still want you to use a voltmeter! cheers, Aus Okay, sorry for the late response. New day new voltmeter approach. So with a voltmeter I get .756 volts when the sensor is clear and .950 volts when the sensor is covered. Quote Link to comment Share on other sites More sharing options...
C_R_PLC Posted June 1, 2018 Author Report Share Posted June 1, 2018 Could it have something to do with the setup that I'm using to power it? I have a variable voltage output powering the sensor itself because it has to be set to 5V, so the positive and negatives are coming from that machine instead of the PLC. Quote Link to comment Share on other sites More sharing options...
sgull Posted June 1, 2018 Report Share Posted June 1, 2018 Hi I would say it is a wiring issue. Make sure you common the 0 volt of your supply with the 0 volt of the PLC. Quote Link to comment Share on other sites More sharing options...
MVP 2023 Ausman Posted June 1, 2018 MVP 2023 Report Share Posted June 1, 2018 23 hours ago, Ausman said: especially that your 0V are commoned correctly. Or better yet, run the arduino from a converter running from the plc supply, but again with the 0V commoned. Quote Link to comment Share on other sites More sharing options...
