JJ263 Posted June 6, 2018 Report Share Posted June 6, 2018 Does anyone know which bit is activated when the Snooze button on the Alarm Banner is pressed ? I have some logic to operate an alarm annunciator (siren and light) that I would like to silence when the snooze button is used. So far I have had to work around this by giving the operator access to a separate alarm silence button on every screen. Or alternatively is there a bit that is set when the onboard alarm tone is activated ? Quote Link to comment Share on other sites More sharing options...
EduMarg Posted August 16, 2018 Report Share Posted August 16, 2018 Hello, There is not system bit that is turn on when the user has selected the snooze alarm button on the banner and there is no direct way to mute alarm sounds when this button is pressed. You'll need to create a logic to manually shut down the alarm sound. you may add a button on the HMI that the user can press after pressing the snooze button and add on the logic a timer. You may add the timer on the HMI to let the user see how much time has pass or even to let him change the amount of time to mute the sound. Quote Link to comment Share on other sites More sharing options...
Willow1580 Posted March 12, 2019 Report Share Posted March 12, 2019 It would be a lot nicer if the built-in silencing button could work to silence whatever external alarm sounds there are. Are there any plans to add this functionality? 1 Quote Link to comment Share on other sites More sharing options...
