Jakke_SL Posted June 22, 2018 Report Share Posted June 22, 2018 I need to communicate with 2 IO-Link masters via Ethernet/IP. The manufacturer of the IO-Link masters provides an EDS file for this devices. I don't find a possibility to import them in to the configuration of the Ethernet/IP protocol (like I normal do for Canopen). Is there an other way? Quote Link to comment Share on other sites More sharing options...
Pista Posted June 23, 2018 Report Share Posted June 23, 2018 Hi voiptel, Unfortunately The EDS file compiler for EIPscanner does not exist in the unilogic programmer. I've created global tags from EDS. You must import global Tags into the program. For example, look the file TagsforJXC91.xls Here is Tags input-output for Keyence Camera CVX400 and motor driver JXC91. TagsforJXC91.xls Quote Link to comment Share on other sites More sharing options...
Jakke_SL Posted June 25, 2018 Author Report Share Posted June 25, 2018 Thanks for your fast answer. If I send you the EDS-file, can you help me to create the globaltags? Kind regards EDS-V3.11.1-PepperlFuchs-ICE1-8IOL-G60L-V1D-20170323.eds Quote Link to comment Share on other sites More sharing options...
Pista Posted June 26, 2018 Report Share Posted June 26, 2018 That EDS file is for all variations of IO modules. You have to tell me the exact module type and what type of assembly ID you will use. for example: Quote Link to comment Share on other sites More sharing options...
Jakke_SL Posted June 26, 2018 Author Report Share Posted June 26, 2018 Dear Pista, Thanks for your help so far. I need to control 15 valves of Bürkert via IO-Link and 1 digital output for a solenoid valve. The valves of Bürkert are proportional valves and controlled via the IO-Link protocol. This means I need 2 P&P IO-Link masters. See attachment for more info. I hope you have enough with this info. Kind regards MA8691-IODD_ENen_00.pdf P&P_295313_eng.pdf Quote Link to comment Share on other sites More sharing options...
BenceHorvath Posted June 12, 2019 Report Share Posted June 12, 2019 Dear Pista! Could you please help me how to create global tags from an .EDS file? I would like to work with an Balluff IO link master devices, but I can't handle it. I have the .eds file of the device, but faced, it has no chance to import the tags in the software. So, somehow I have to create my own glob. tags in order to reach my IOmaster device. Thanks in advance! Regards.: Bence Quote Link to comment Share on other sites More sharing options...
Pista Posted June 14, 2019 Report Share Posted June 14, 2019 Hello, Sorry everyone. For a lot of work I did not solve the I / O link EDS. Our company plans to use IO Link devices with PLCs Unitronics. Can you publish EDS file and the exact type of IO Link devices? Quote Link to comment Share on other sites More sharing options...
BenceHorvath Posted June 14, 2019 Report Share Posted June 14, 2019 1 hour ago, Pista said: Hello, Sorry everyone. For a lot of work I did not solve the I / O link EDS. Our company plans to use IO Link devices with PLCs Unitronics. Can you publish EDS file and the exact type of IO Link devices? Dear Pista! Thank you for your support! I've attached the .eds file I have. My type is BALLUFF BNI EIP-508-105-Z015 If I see right, that eds is belonging only for this device. Furthermore, I would like to use an RFID reader and some IO link sensors connected to this master device. Thanks again! Regards: Bence BNI EIP-508-105-Z015.eds Quote Link to comment Share on other sites More sharing options...
Cam Posted June 14, 2019 Report Share Posted June 14, 2019 I’ve interface and Ethernet IP reader I. To a unistream before. Any chance your using one from RFideas? If so I can send you the struct required. 1 Quote Link to comment Share on other sites More sharing options...
Pista Posted June 16, 2019 Report Share Posted June 16, 2019 Ahoj Bence, posielam tagy pre EIP komunikáciu. Rýchlo napísané, podrobnosti iba pre port-0. Hi Bence, I send tags for EIP communication. Quickly typed, details only for port-0. Link for Inspiration.: Balluff_GlobalTags.xls BalluffStructs.xls 1 Quote Link to comment Share on other sites More sharing options...
BenceHorvath Posted June 19, 2019 Report Share Posted June 19, 2019 On 6/14/2019 at 7:48 PM, Cam said: I’ve interface and Ethernet IP reader I. To a unistream before. Any chance your using one from RFideas? If so I can send you the struct required. Dear Cam! Yes please, I have to use some Io link sensors, and after an RFID Reader/writer connected to this IOlink master device. I would appreciate if you have any useful information, because I'm a beginner in this subject, and this is my first such a project. Regards, Bence Quote Link to comment Share on other sites More sharing options...
Cam Posted June 19, 2019 Report Share Posted June 19, 2019 Hi Bence, Heres the Structs for the one we used, the reader wasn't connected to and IO link Master though just communicating over Ethernet/IP to the PLC. RFCardReaderEthIP.ulpr Quote Link to comment Share on other sites More sharing options...
BenceHorvath Posted June 21, 2019 Report Share Posted June 21, 2019 Dear Members! I have successfully connected with the IOLINK master device. Important to match the names an the BIG letters at the excel file. I had to fix few little things in the tag files, but the communication is OK now between the IOmaster and the PLC. The next step to reach the RFID reader, but I didn't find the right port setting, how can I activate the IO link port, and communicate with the reader. If somebody have useful info about, please not hesitate to write If I find the solution, I'll share it with you. Regards, Bence Quote Link to comment Share on other sites More sharing options...
