ThaisCouto Posted June 26, 2018 Report Share Posted June 26, 2018 Hello, I've tried to search on all forums, but the closest article was this one - which didn't help me to find a workaround http://forum.unitronics.com/topic/5254-admin-users-in-unilogic/?tab=comments#comment-20148 I am from IT department and one of our sales person need to install VisiLogic on his computer to help a customer how to use our products. I couldn't find a way to run the software without elevation, it is worling only with Admin rights. I am from IT department, I 've tried in different computers I also installed on my computer and tried with a non-admin login, didn't work. Am I missing any step on the installation? Quote Link to comment Share on other sites More sharing options...
Cam Posted June 27, 2018 Report Share Posted June 27, 2018 Right click on the exe file. Properties then look at the compatibility tab there should be a check box for run as administrator. Check it and you will still have to select to apply it for all users. Quote Link to comment Share on other sites More sharing options...
ThaisCouto Posted June 27, 2018 Author Report Share Posted June 27, 2018 11 hours ago, Cam said: Right click on the exe file. Properties then look at the compatibility tab there should be a check box for run as administrator. Check it and you will still have to select to apply it for all users. Thanks for your suggestion, Cam. I've tried to check this option first and then for all users. Both options had no change on the behavior, when I double click on the .exe to open the application, it requires the admin password. Any other? Quote Link to comment Share on other sites More sharing options...
NahumS Posted June 27, 2018 Report Share Posted June 27, 2018 One of the reasons that your settings could not be save - It's sounds like you are using a basic user credentials. Contact your IT or an IT person which will define you an administrator credentials to have the ability of add/remove/change system settings. Good Luck! Quote Link to comment Share on other sites More sharing options...
ThaisCouto Posted June 27, 2018 Author Report Share Posted June 27, 2018 2 hours ago, NahumS said: One of the reasons that your settings could not be save - It's sounds like you are using a basic user credentials. Contact your IT or an IT person which will define you an administrator credentials to have the ability of add/remove/change system settings. Good Luck! Thanks for your help, NahumS. I am from IT department and according to our internal policy, this is not an option. I cannot give a sales user Admin rights on his computer. That's the reason I need help ? Quote Link to comment Share on other sites More sharing options...
CarlosMDC Posted November 15, 2018 Report Share Posted November 15, 2018 Any update on this issue? I am having the exact same problem with standard user trying to open visilogic.exe and asking for admin credentials. The option in compatibility mode is unchecked but the .exe will insist anyway Quote Link to comment Share on other sites More sharing options...
MVP 2023 Flex727 Posted November 15, 2018 MVP 2023 Report Share Posted November 15, 2018 9 minutes ago, CarlosMDC said: Any update on this issue? This is a user forum. While Unitronics employees occasionally weigh in, this forum is mostly populated by users who are not directly affiliated with Unitronics. I recommend that you send an email to support@unitronics.com to get an answer directly from the source. 1 Quote Link to comment Share on other sites More sharing options...
