G. Asgeirsson Posted June 29, 2018 Report Share Posted June 29, 2018 Hi, I am new here :-). Thanks for this great forum. Looking forward to learning and contributing. I have set up a remote connection to my UniSteam USP-156-B10 using a VNC client. So now the UniStrem PLC is accessible from the internet. It was easy, I only needed to configure port forwarding on ports 5800 and 5900 in my router, and obviously connect on the outer IP address However I have problems connecting to the UniStream from UniLogic. I have forwarded the ports (22 and 3335) in my router but I still can not connect. I did enable UDP and TCP. The configurations in the router are exactly the same for VNC and UniLogic except for the ports (5800,5900 for VNC and 22,3335 for UniLogic) Does anyone know what I am doing wrong? Are the UDP and TCP protocols not enough? 1 Quote Link to comment Share on other sites More sharing options...
greml1n Posted July 12, 2018 Report Share Posted July 12, 2018 Try going to project in the toolbar. Then options. Then try unchecking ping on discovery 1 1 Quote Link to comment Share on other sites More sharing options...
G. Asgeirsson Posted July 27, 2018 Author Report Share Posted July 27, 2018 That did the trick. Thanks ever so much for your help, I really appreciate it. Quote Link to comment Share on other sites More sharing options...
