Carney Posted July 9, 2018 Report Share Posted July 9, 2018 When we are connecting up to our V430 PLC's and we want to change a number field, like changing the date/time, we can click on the number field and it will open up a screen with the first number field flashing but there is no keypad to enter numbers from. The second thing that is happening is that we get an error message saying that Info Mode is not supported, do you have an expected timeline for when this might be changing. thanks Quote Link to comment Share on other sites More sharing options...
Saragani Posted July 10, 2018 Report Share Posted July 10, 2018 Read the Fonts and Images cache from the PLC in order to see the keyboard. The Info mode is not expected to be supported. Quote Link to comment Share on other sites More sharing options...
MVP 2023 Ausman Posted July 10, 2018 MVP 2023 Report Share Posted July 10, 2018 5 hours ago, Saragani said: Read the Fonts and Images cache from the PLC in order to see the keyboard. OK, I read this and in puzzlement looked around in the program and also RAccess, and found another thing I haven't ever really noticed. Learn something new every day! cheers, Aus Quote Link to comment Share on other sites More sharing options...
Carney Posted July 10, 2018 Author Report Share Posted July 10, 2018 Sorry, I thought about it last night and I neglected to say that when we connect to the PLC it says that the cache is being read. We also use a V700 and do not have the same issue. As far as I can tell, I didn't do the original program, it appears that both the PLC's are setup the same for remote access. thanks Quote Link to comment Share on other sites More sharing options...
MVP 2023 Flex727 Posted July 10, 2018 MVP 2023 Report Share Posted July 10, 2018 Did you try re-downloading the cache? Quote Link to comment Share on other sites More sharing options...
Saragani Posted July 11, 2018 Report Share Posted July 11, 2018 Different PLCs, different keyboards. Some of the keyboards are already cached within the built-in cache that comes with Remote Operator / Access, but you should read cache anyway, in order to support fonts that are used in the project, and other images that were added to project as well. Quote Link to comment Share on other sites More sharing options...
Carney Posted July 11, 2018 Author Report Share Posted July 11, 2018 With PC Remote Operator we were able to download the cache (images/fonts) from the PLC and then the keyboard was available but haven't been able to locate this same option on our mobile devices. Is there such an option or should it be doing this automatically, when starting the app it does ask if we want to download the app and we answer yes. Quote Link to comment Share on other sites More sharing options...
