Meetto Posted July 14, 2018 Report Share Posted July 14, 2018 Dear sir/Madam, I downloaded latest version of UniLogic, 1.24 version 48. Now the program is not opening. Can you help please? Quote Link to comment Share on other sites More sharing options...
Saragani Posted July 14, 2018 Report Share Posted July 14, 2018 Have you tried running the UniLogic Diagnostics? Quote Link to comment Share on other sites More sharing options...
Meetto Posted July 16, 2018 Author Report Share Posted July 16, 2018 Dear sir, No, I revert back to 1.18 with system restore. Quote Link to comment Share on other sites More sharing options...
Saragani Posted July 18, 2018 Report Share Posted July 18, 2018 OK. Btw, if the Diagnostics shows that everything is OK, and the splash screen shows and disappears after a second or more, then it can be a various of reasons. If you are using Windows 7, then run the following exe and see if it helps: https://dotnetbinaries.blob.core.windows.net/kbassets/KB4074906/fixittool-KB4074906.exe If that doesn't help, then download and install .Net framework 4.7.1: https://download.microsoft.com/download/9/E/6/9E63300C-0941-4B45-A0EC-0008F96DD480/NDP471-KB4033342-x86-x64-AllOS-ENU.exe Quote Link to comment Share on other sites More sharing options...
