LAPUSA Posted July 16, 2018 Report Share Posted July 16, 2018 I have set up a Web Server on a V570. Once I view the page within a short time the refresh page is no longer functioning, and the page is not reachable. Have to reboot PLC to reset the connection in order to view page. I also notice the within a few seconds of viewing the page, SB 149 value change to 1 and no long connection. Does anyone and a fix. Thank you Quote Link to comment Share on other sites More sharing options...
MVP 2023 Ausman Posted July 16, 2018 MVP 2023 Report Share Posted July 16, 2018 1st thing is to check is that SB168 is set to do a power up value of 1. When you look at it in SBs, it is self-explanatory. But I suspect your problem might be something else. cheers, Aus Quote Link to comment Share on other sites More sharing options...
LAPUSA Posted July 17, 2018 Author Report Share Posted July 17, 2018 YES, SB168 has the power-up value of 1. Quote Link to comment Share on other sites More sharing options...
DanT Posted July 18, 2018 Report Share Posted July 18, 2018 I have a V350 Demo sitting on an IP address. I have run into this issue before. One solution I have implemented is to Reset the PLC at Midnite. This can be done thru SB300. Also , The Vision Series PLC's can handle only 1 Internet connection at a time. Quote Link to comment Share on other sites More sharing options...
