Steve Posted April 7, 2011 Report Share Posted April 7, 2011 Hello, When uploading the program from a V290, I got the following error: "element not exist in the list IO-AI1X-A03X". I couldn't find what the error means, could someone tell me? Thanks Quote Link to comment Share on other sites More sharing options...
Jas Posted April 7, 2011 Report Share Posted April 7, 2011 Please close VisiLogic and extract the attached file. Double click it and make sure that you receive the following message: Now go to C:\Program Files\Unitronics\Unitronics VisiLogic_C\Data\HW Cfg Make sure that there is a file called IO-AI1X-AO3X.ini Make sure that IO-AI1X-AO3X is listed in ElementsList.ini under the expansion I/O section C:\Program Files\Unitronics\Unitronics VisiLogic_C\Data\HW Cfg\Elements List Now open VisiLogic and choose the PLC model and verify the expansion module is available: Please let us know if it helps! Enable AI1X_A03X.ZIP Quote Link to comment Share on other sites More sharing options...
Steve Posted April 11, 2011 Author Report Share Posted April 11, 2011 Jas, This solution fixed my problem. Thanks a lot! Quote Link to comment Share on other sites More sharing options...
