Bluecolor Posted July 28, 2018 Report Share Posted July 28, 2018 I'm new to unilogic but not a beginner in automation, but there is a thing I can't work out. The machine is going to sort a product to different positions. We are counting pulses from a pulscounter on a continuous rolling convayer, and the positions are different pulses away from the measure position. In a table we have the values: positon, min diameter, max diameter, min lenght and max length In another table we have: position and pulses when the measuring is done we would like to get the position that match both diameter in range of min and max diameter and lenght in range of min and max length and when the product reaches that position it will be pushed off the convayer. There could be as much as 12 products at the same time on the convayer and maybe some is going to be pushed off at the same position. I hope some of you can help me or give me a push in the right direction. Thanks! Quote Link to comment Share on other sites More sharing options...
NahumS Posted January 8, 2019 Report Share Posted January 8, 2019 Hello Bluecolor, The description you wrote down are too general. Please let me know what kind of requirements you need for your devices. I need you to send the devices you are using and their specs + IG (Installation Guide). The controller you wish to implement it one an so on... If you would like to work over email cooresponding you can send all the inforamtion + files to support@unitronics.com and mention my Name over there so I will continue handling you ticket. Looking forward for your reply. Quote Link to comment Share on other sites More sharing options...
