lesmar96 Posted August 3, 2018 Report Share Posted August 3, 2018 I have been editing and adding to a Visilogic program written in the last version of Visilogic. (BTW. I finally did get Visilogic to install correctly) While working on the graphics, arranging the screens, I suddenly got an error. And it immediately crashed Visilogic. Now every time I open it, I get an error ( see attached) . I can get passed it, but I basically doesn't let me do anything on that hmi panel. It just crashes the software any time I try to do something. Pretty frustrating...............Any help? And I even am running as administrator! This software seems to have a lot of glitches. Quote Link to comment Share on other sites More sharing options...
lesmar96 Posted August 3, 2018 Author Report Share Posted August 3, 2018 here is another error I get. Quote Link to comment Share on other sites More sharing options...
lesmar96 Posted August 3, 2018 Author Report Share Posted August 3, 2018 it doesnt seem there is any information in the help menu on what could be causing these issues Quote Link to comment Share on other sites More sharing options...
MVP 2023 Flex727 Posted August 3, 2018 MVP 2023 Report Share Posted August 3, 2018 I recommend contacting Unitronics Support directly at support@unitronics.com, or you can open a support ticket at http://support.unitronics.com/ . Although this forum is hosted by Unitronics, it is a user forum and is mostly populated by other users like you and me. Quote Link to comment Share on other sites More sharing options...
Rodrigo Borges Posted April 17, 2020 Report Share Posted April 17, 2020 you are trying to open new prohect with an old software version. The database of the project is 152 The database of the project is 154 you cannot load this project - new file will be opened. but I am using the same version of the software, I closed the application and reopened it 20 minutes later and now only this message appears. Quote Link to comment Share on other sites More sharing options...
MVP 2023 Flex727 Posted April 17, 2020 MVP 2023 Report Share Posted April 17, 2020 What version of the software are you using and what is the PLC model? Did you create the program yourself? When was the last time you saved the program? Quote Link to comment Share on other sites More sharing options...
MVP 2023 Ausman Posted April 18, 2020 MVP 2023 Report Share Posted April 18, 2020 For interest's sake, have you tried the method described here: http://forum.unitronics.com/topic/6157-how-to-convert-programs-developed-in-9879-to-9865/?do=findComment&comment=25144 This might not work in your situation, but perhaps try variations on the basic idea. cheers, Aus Quote Link to comment Share on other sites More sharing options...
