Jared H Posted August 17, 2018 Report Share Posted August 17, 2018 Hello, I am trying to port a complete V430-J-R34 program to a Samba Series SM43-J-R20. I have the Main Module, subroutines, string libraries and recipes all transferred over via the appropriate Import/Export functions. What I am having trouble with is transferring/copying all the HMI Displays. Changing the Hardware Configuration and keeping the program is not allowed between different models. Is it possible to somehow manually transfer/copy the displays across models? We have 2 similar programs. The default V430 program includes a couple more outputs than what the Samba could provide. I have removed the outputs that were deemed unnecessary in order to use it on a Samba. Quote Link to comment Share on other sites More sharing options...
MVP 2023 Flex727 Posted August 17, 2018 MVP 2023 Report Share Posted August 17, 2018 How many HMI screens do you have in the program? Probably the easiest thing to do is to open the V430 project, go to the first HMI screen, Ctrl-A, Ctrl-C, open the Samba project, go to the first HMI screen, Ctrl-V. Save & repeat for each screen. Quote Link to comment Share on other sites More sharing options...
Jared H Posted August 21, 2018 Author Report Share Posted August 21, 2018 DOH! So originally I had tried the Ctrl+A, Ctrl+C and it did not work. I have a bad habit of closing down VisiLogic when switching to a different program, so the "clipboard" data is lost as well..... Problem solved by leaving VisiLogic open and switching programs. Quote Link to comment Share on other sites More sharing options...
