Jeff164 Posted September 4, 2018 Report Share Posted September 4, 2018 Using a Samba 7 PLC, SM70-J-RA22, with the snap in Ethernet module installed. Unable to establish communication with the unit. Have verified the IP address, Subnet Mask & Gateway assigned is the same in both the communication setup FB's as well as the remote PC's communication window. Below is the lines of ladder logic that initialize the Ethernet module, let me know if you see something obvious here. IT is not my specialty, so this is a bit more challenging for me... everyday is a learning experience Thanks ! Jeff Quote Link to comment Share on other sites More sharing options...
MVP 2023 Flex727 Posted September 4, 2018 MVP 2023 Report Share Posted September 4, 2018 Check the example projects that came with your VisiLogic installation for the proper way to set up this type of communications. Quote Link to comment Share on other sites More sharing options...
