Meetto Posted September 5, 2018 Report Share Posted September 5, 2018 Dear sir/Madam, Have good day. I brought new JAZZ , JZ20_J_R16, After programming I tried to load the program to JAZZ. but it is not downloading. I am using USB, in my computer it is connected to STM electronics Virtual COM port (COM17) found in system device.. In Jazz it is COM 1, Am I doing anything wrong. please Help. How can I load program to JAZZ. Need an urgent help. Quote Link to comment Share on other sites More sharing options...
Kikis Posted September 5, 2018 Report Share Posted September 5, 2018 To be able to establish connection, you need to install USB driver. There is a button to do this within U90 ladder software as shown in the photo below (Controller / M90 OPLC SETTINGS). Make sure you use the same COM port number in U90 PC communication settings. Quote Link to comment Share on other sites More sharing options...
sgull Posted September 5, 2018 Report Share Posted September 5, 2018 Hi Meetto If the port is COM17 in device manager then you must select COM17 in the unitronics program communication settings. However I think that the program only accepts COM ports up to 16. Try changing the COM port in device manager to an unused port below 16 and match the settings in the Unitronics program Quote Link to comment Share on other sites More sharing options...
Meetto Posted September 5, 2018 Author Report Share Posted September 5, 2018 Dear sir/Madam, I Have 4 USB ports and tried all the ports. It is same showing COM 17. I installed USB driver and restarted. still same. Quote Link to comment Share on other sites More sharing options...
Meetto Posted September 5, 2018 Author Report Share Posted September 5, 2018 Dear Sir/madam, have good day. I changed the virtual port setting in device manager to COM 2 and now it is working. Thank you for the time. Quote Link to comment Share on other sites More sharing options...
