Jakke_SL Posted September 13, 2018 Report Share Posted September 13, 2018 Hey, I am trying to connect an IO-Link master to a Unistream 7". I configured a Scanner node. Everything is going well, except when I try to configure the Configutation assembly, I am receiviong the "EthernetIP Connection Status Message": 0x0020. This message is not in the list (the list starts with 0x0100) I need some help, please. Kind regards. Jan Quote Link to comment Share on other sites More sharing options...
MVP 2023 Ausman Posted September 18, 2018 MVP 2023 Report Share Posted September 18, 2018 Hi Jan Is this entire page your reference? Or it might help? https://unitronicsplc.com/Download/SoftwareHelp/UniLogic_Knowledgebase/Communications/EthernetIP.htm cheers, Aus Quote Link to comment Share on other sites More sharing options...
