Skye Posted April 12, 2011 Report Share Posted April 12, 2011 Hi, I'm about to start a new project and would like to ceate the operand labels in Excel and then import them into the project as this should be much faster than typing them directly into Visilogic. I believe I'm correct in saying this is possible, could you please point me in the direction of any information that describes the format required.but Many Thanks Quote Link to comment Share on other sites More sharing options...
MVP 2023 Joe Tauser Posted April 13, 2011 MVP 2023 Report Share Posted April 13, 2011 Start by doing a descriptor export from Visilogic- Edit->Export Operands Descriptions. This will give you an easy-to-read file with the proper format that you can edit in Excel and then re-import. Joe T. Quote Link to comment Share on other sites More sharing options...
