CltOff Posted April 12, 2011 Report Share Posted April 12, 2011 Hi to everybody, is there a way to obtain an automatic Application "data flow" report, to use for a software specification (even if at basic level) to give to the customer? Best regards CltOff Quote Link to comment Share on other sites More sharing options...
Emil Posted April 12, 2011 Report Share Posted April 12, 2011 I'm not sure I understand your need... Quote Link to comment Share on other sites More sharing options...
CltOff Posted April 15, 2011 Author Report Share Posted April 15, 2011 I'm not sure I understand your need... You're right. My question was too general. I try to explain better. If I've developed an application and my customer is asking me the sortware documentation I've to create a document that describe the data flow diagram from Input to Output passing from decisional points. Normally it is a boring work. If it could be possible to have in automatic mode the data flow diagram (maybe checking routines that has to be included in the report an routines that hasn't), it should be easier to generate software documentation. I know that isn't an easy job... but asking is "free of charge".... I know that using the print options it's possible to create a report, about the application, but isn't easy to "read" and it "discovers" too much the implemented application. I hope now I've been more clear. Attached some data flow examples. Best regards CltOff Quote Link to comment Share on other sites More sharing options...
