sunit Posted September 23, 2018 Report Share Posted September 23, 2018 I REPLACED A CNC CONTROLLER WITH V130-J-TR34 FOR CONTROLLING X,Y TABLE OF AUTO PUNCHING MACHINE FOR SHEET METAL. FEATURES 1. AUTO , SEMI AUTO , MANUAL MODE 2. SYNCHRONIZING THE X,Y TABLE WITH THE PRESS MACHINE. 3. SHEET METAL SIZE 2M x 2M UPTO 1000 HOLES POSITION CAN BE STORED 4. AUTOCAD FILE CAN BE TRANSFERRED TO PLC Quote Link to comment Share on other sites More sharing options...
Isakovic Posted September 24, 2018 Report Share Posted September 24, 2018 13 hours ago, sunit said: 4. AUTOCAD FILE CAN BE TRANSFERRED TO PLC That is great. Quote Link to comment Share on other sites More sharing options...
Kikis Posted September 24, 2018 Report Share Posted September 24, 2018 Hi Sunit, Great work! I have successfully completed a similar project in the past. I'm using CAM software to extract X-Y hole center coordinates from the CAD file which i store in a data table for positioning. Could you please share how did you manage to transfer AUTOCAD DWG files to V130? Quote Link to comment Share on other sites More sharing options...
sunit Posted September 28, 2018 Author Report Share Posted September 28, 2018 On 9/24/2018 at 11:39 AM, Kikis said: Hi Sunit, Great work! I have successfully completed a similar project in the past. I'm using CAM software to extract X-Y hole center coordinates from the CAD file which i store in a data table for table positioning. Could you please share how did you manage to transfer AUTOCAD DWG files to V130? Transferring autocad coordinates to excel file . Importing that excel to data table. 1 Quote Link to comment Share on other sites More sharing options...
Kikis Posted September 28, 2018 Report Share Posted September 28, 2018 4 hours ago, sunit said: Transferring autocad coordinates to excel file . Importing that excel to data table. Thanks for your reply, i did exactly the same thing. Quote Link to comment Share on other sites More sharing options...
Kikis Posted November 3, 2018 Report Share Posted November 3, 2018 @Cara Bereck Levy Btw for such applications which require X-Y servo positioning, it would be great to have a special PTO function block to perform synchronized linear motion using the 2 axes (Linear interpolation). Quote Link to comment Share on other sites More sharing options...
BertyM8 Posted July 4, 2020 Report Share Posted July 4, 2020 Hi, could you provide some info or maybe your program file for the XY table? I am developing an application of cutting wooden leg ends into oval shapes with 2 sides straight and then two half circle sides. I am using 2 steppers for X and Y movement. I have reached the point where they get initialized on end switches, then using PTO absolute movement I drive them to the starting point (let's say X=600 and Y=40), then only X goes forward to X=1000, while Y stays in place, cutting the right straight side. The problem is when I try to make a U turn using X and Y PTO absolute move, which doesnt go the way I'm doing it. I am trying with linearization block to change the position of X depending on Y, but should I use a self written formula instead? Linearization makes it go sideways at 45° and after doing half the target for Y I switch the X to go back. Thus I am making a V instead of U turn. Can this be similarly solved with a data table where I can draw points in the U turn and then it will change the target positions dinamically in this way? Quote Link to comment Share on other sites More sharing options...
