Hello Unitronics.
Help Center Eduardo Margulis 19th Nov. 2017 wrote:
Configure the CANbus port using a COM init function set to CANopen + J1939.
Note that the ECU adress used by theJ1939 protocol is the Vision Unit ID number, which is contained in SI 8 when COM init runs.
After the COM init function, place the J1939 Configuration function. This has three tabs comprising the parameters listed below.
Note that the status parameter, J1939 Configuration startup process status provides status messages for all tabs in the Configuration
QUESTION: Tab name, what is the configurations parameters for my V570 Plc ( 64 bit or 8 bytes ) The Plc is only to communicate with one (1) diesel engine.
Thank you.
