MalSnaize Posted October 7, 2018 Report Share Posted October 7, 2018 (edited) Hi all, some guidance please. I am displaying text labels on a V1210 screen I have a common block of MIs that I use to display the various string labels (Tank names, Pump names, Product names). The labels vary in length (eg: Tank = 6 characters in 3 MIs, product = 20 characters in 10 MIs) The Tank screen displays 40 x 6-char labels and the Product screen displays 20 x 20-char labels (please see display export). After initialising label length and number of labels I use a common net to display 1 label per cycle (see attached net). The net reads a table and copies the data to the MI offset for the current record number. Each screen label is mapped to its associated offset of the common block. When displaying the Product screen only (20-character) 11 labels are displayed and when displaying the Tank screen only the first 20 plus the 33rd labels are displayed (3-characters). When the screen is only showing around half the labels, if I manually set SB31 (refresh variable) (ie via the Visilogic connection to the PLC) then all labels suddenly appear. Also if I touch any label and the HMI keyboard appears, either ENTER or ESC also causes all the labels to appear. However if I try to set 31 programmatically in the NET when all labels have been displayed, it does not update the display. Final note, after all labels have been loaded and half not showing, looking at the live data via Visilogic shows the MI block for the screen labels is fully populated with the correct data. So it seems to be a refresh issue but I am snookered as to what it is.. Any thoughts from anyone? Thanks Mal Tank Edit 20181007a.bmp Edited October 7, 2018 by MalSnaize noticed addional behaviour now documented Quote Link to comment Share on other sites More sharing options...
MVP 2023 Joe Tauser Posted October 7, 2018 MVP 2023 Report Share Posted October 7, 2018 Are you triggering the Refresh bit associated with the specific string display text object? You may need a separate bit for each one. Post your code if it would help. Joe T. 1 Quote Link to comment Share on other sites More sharing options...
MalSnaize Posted October 7, 2018 Author Report Share Posted October 7, 2018 Joe thanks for your rapid response and apologies for my slow one - I'm in a different time zone. Ah ok so I have been a bit lazy here and used the same trigger bit on all objects - I'll assign unique ones for each and see how that goes; back soon! cheers Mal 1 Quote Link to comment Share on other sites More sharing options...
MalSnaize Posted October 8, 2018 Author Report Share Posted October 8, 2018 Hi Again Joe - worked a treat thanks - the table now displays nice and smoothly too At the moment I trigger on each cycle for each label as the table of text is built; I wonder would it be better (or indeed worse) to build all of the data and then write all the triggers at once? Just a thought. Quote Link to comment Share on other sites More sharing options...
Gabriel Franco Posted October 8, 2018 Report Share Posted October 8, 2018 Usually I use same Refresh bit for all Text fields and then SET it in ladder once per second. Quote Link to comment Share on other sites More sharing options...
MalSnaize Posted October 10, 2018 Author Report Share Posted October 10, 2018 Thanks Gabriel - yes I too previously used one bit to trigger a number of text fields. The problem arose when I increased the number of text fields significantly (one screen has 16 x 20 character fields plus a whole load of static information. The other screen has 40 fields of 6 characters. So I'm thinking maybe theres a limit to how much data can be refershed in one scan (has to be, right?) Supporting that, following Joe's advice and introducing individual trigger bits it has fixed the issue - I guess the OS simply looks after it nd determins how much it can referesh in one cycle then comes and finishes off the rest in subsequent cycles (thats just a guess) anyway end of the story is that it now works! thanks all 1 Quote Link to comment Share on other sites More sharing options...
