sergiog860
CPU error
Hi, I have a problem with a CPU unistream.
I downloaded the operating system and I installed it in the plc. but now appear in the display "CPU error detected" and the plc not recognized the cpu.
Can someone tell me how to solve the problem?
Thank you
16 minutes ago, marcelo_chaura said:
Hola, tengo el mismo problema con la pantalla HMI unistream y me da error , alguien tiene la solucion al tema? Saludos
Translation:
"Hello, I have the same problem with Unistream HMI screen and gives me error, someone has the solution to the issue? regards"
Please post your problem description in the UniStream forum as a new topic.
