wer Posted October 18, 2018 Report Share Posted October 18, 2018 How to create XML (ulri) file in third part application an then import it in Visilogic STRUCT function? I cant find any example of this file... Quote Link to comment Share on other sites More sharing options...
MVP 2023 Ausman Posted August 10, 2022 MVP 2023 Report Share Posted August 10, 2022 I'm again having to change some structs around, and as usual I ponder the "Import" facility which wer quite rightly asked about. Any clues, anyone? And if it's an import, why can't we do an export? I get the feeling that such things would make life a lot easier, as the file could be referenced in collect/extract matchings. But how to go about it appears to be one of those little mysteries that the creators have made for us. 🤔 @Cara Bereck Levy I'll ping you in on this, just in case you know and it hasn't appeared in any help files. cheers, Aus Quote Link to comment Share on other sites More sharing options...
MVP 2023 kratmel Posted August 10, 2022 MVP 2023 Report Share Posted August 10, 2022 I test URB module I/O configurator menu in project Hardware Configuration embedded to new Visilogic version. If some configuration of URB I/O modules is present (created), you can select register configuration for inputs and outputs. Then you can export .ulri files for inputs and ouputs to folder. After that this files can be imported to Visilogic STRUCT function for collect or send data via URB modules. Quote Link to comment Share on other sites More sharing options...
MVP 2023 Ausman Posted August 11, 2022 MVP 2023 Report Share Posted August 11, 2022 Kratmel, I assume this is in Visilogic versions later than 9.8.65. But I'm left puzzled how something for the modules relates to Structs? Wondering if you could post an actual example of a saved .ulri so that I can get an idea of the format etc. I am perhaps mistaken in thinking that they would be a small file. cheers, Aus Quote Link to comment Share on other sites More sharing options...
MVP 2023 kratmel Posted August 12, 2022 MVP 2023 Report Share Posted August 12, 2022 Two files imputs and outputs from my experiment. Version 9.8.91 used. Inputs.ulri Outputs.ulri I think it is possile to generate this file by copy paste or write simple macro code. Quote Link to comment Share on other sites More sharing options...
MVP 2023 Ausman Posted August 12, 2022 MVP 2023 Report Share Posted August 12, 2022 Thanks Kratmel, I'll look at them deeper tomorrow but at first glance I can't see how they're going to help as it seems there's not enough info in them. I think I really am going to need a proper example from the Creators. cheers, Aus Quote Link to comment Share on other sites More sharing options...
