eFisher0409 Posted October 18, 2018 Report Share Posted October 18, 2018 Hello I’m new to plcs especially unitronics and visilogic, I need help making a program with a touchscreen start button, that will spin a motor forward for a certain amount of time and then reverse the direction for a certain amount of time then repeat the process, the switch needs to be On timers as I want to walk away and let my program run for hours at a time. Thanks hopefully someone can help! Quote Link to comment Share on other sites More sharing options...
Kikis Posted October 20, 2018 Report Share Posted October 20, 2018 Hello, I'm attaching an example i made based on your description. I have set the timers for FWD and REV direction spinning to 3min, but of course you can set the values as you want. EXAMPLE_1.vlp Quote Link to comment Share on other sites More sharing options...
