Don2015 Posted October 19, 2018 Report Share Posted October 19, 2018 Hi, I'm trying to force inputs off or on that are coming from a Ethernet/IP 8-port junction block. Is this possible? Thanks, DonH Quote Link to comment Share on other sites More sharing options...
Guy Sela Posted January 8, 2019 Report Share Posted January 8, 2019 Hi Don The IO`s are updated constantly each scan, so you will get the "true" value of your IO`s. If you are trying so simulate as if your IO is triggered, you can add a contact for input or a coil as output in parallel to your presses that you what to simulate. Quote Link to comment Share on other sites More sharing options...
