CHERIS Posted October 31, 2018 Report Share Posted October 31, 2018 Hello, someone knows how to communicate, control and send images from a vision sensor IV-500 KEYENCE by ETHERNET to CPU USC-P-B10 Quote Link to comment Share on other sites More sharing options...
MVP 2023 Ausman Posted November 1, 2018 MVP 2023 Report Share Posted November 1, 2018 Hi Cheris, this might sound harsh, but the forum does not do your work for you. I once said this in another post: << The real art to programming plcs is to first break down your process to every single procedure you are going to need to achieve your desired result, and then arranging those procedures to achieve this result in the most efficient manner. (You need to remember that in general plcs are very dumb and need to be told how to do everything.) I do this using a spreadsheet owing to the ease of moving things around, but there are many other methods including whiteboards, depending on complexity. (Some people end up with a correctly drawn flow chart once everything is finalised, but for me that isn't needed.) Once you have done that, if there is a procedure needed that you are unfamiliar with, or haven't used before, you then go to your plc's list of things it can do and find the function/maths/compare etc that best matches what you need to achieve. You then learn everything you can about the way it works, by consulting the help files, looking at examples and then physically doing a trial, using the plc, of something simple involving that procedure to ensure you are totally familiar with the way it works. Eventually you can tie it all together into a fully functioning, simple as possible program that the little men, women and gender neutral people (we are very PC on this forum!) running around inside the plc are quite happy to do over and over and over again without getting tired. >> Members of the forum are very glad to help when you have a question regarding an issue/question/problem you discover when developing your own program using the above principles. We all started from basics, using help files and experiments. cheers, Aus 1 Quote Link to comment Share on other sites More sharing options...
Pista Posted November 3, 2018 Report Share Posted November 3, 2018 Hello, To send pictures certainly not, but the command yes. Try it over Ethernet IP. Unfortunately, EDS is not rewritten for Unilogic unistream program. Try to overwrite it from these materials. IV-Tags.CSV Quote Link to comment Share on other sites More sharing options...
CHERIS Posted November 5, 2018 Author Report Share Posted November 5, 2018 Thanks Pista, I have communicated several sensors of keyence with PLC Allen Bradley just like in the video and try to do the same with the unitronics but still there is no communication, I will have to go back to use allen bradley je Quote Link to comment Share on other sites More sharing options...
Swervomotor Posted December 4, 2018 Report Share Posted December 4, 2018 I've got control to work well with Ethernet IP. You need to make sure your CPU IP address is on the same subnet as the IV. Also make sure you check the Ethernet IP box in the IV Navigator. I have attached a screenshot of the Scanner node info I use. If you would like the struct to import PM me and I can send you the exported struct file (it takes a lot of work to build this because the IV has so many objects 390 bytes) As far as sending images and managing them with the Unistream, Tried and failed. I ended up using FTP to send the images directly to our plant network from the IV. The downside to this was I had to get a static IP reservation on our plant network which IT does not like. Quote Link to comment Share on other sites More sharing options...
