Marek Posted November 9, 2018 Report Share Posted November 9, 2018 Hi, I'm trying to activate an output a set time after the enter key has been pressed, but several times. So when the key is pressed the first time a timer starts for say 10s and then activates the output. Whilst this timer is running I would like to start another timer for say 15s with the next key press. I've been trying to have a MB that says timer 1 is active so start timer 2 but all I can achive is for both timers to start when the enter key is pressed the first time. What I have so far attached and any pointers would be greatly appreciated. Thanks Quote Link to comment Share on other sites More sharing options...
MVP 2023 Ausman Posted November 10, 2018 MVP 2023 Report Share Posted November 10, 2018 I'll think about this and respond when I have more time, but I have to ask the question why don't you want to use different keypad numbers to activate a timer matched to that number? I can see all sorts of issues arising with what you want to do, especially with things getting very confusing for the screen user. cheers, Aus Quote Link to comment Share on other sites More sharing options...
Marek Posted November 11, 2018 Author Report Share Posted November 11, 2018 Hi, I have been working on this again and realised I needed to put the button press logic in one net. the below is working for me now. Thansk to those who looked at this. Quote Link to comment Share on other sites More sharing options...
MVP 2023 Flex727 Posted November 11, 2018 MVP 2023 Report Share Posted November 11, 2018 8 hours ago, Marek said: I have been working on this again and realised I needed to put the button press logic in one net. Very nicely done! Quote Link to comment Share on other sites More sharing options...
